Assuming that drop wasn't just due to cooling, it gets difficult.
First I'd be looking in the boiler. Does it drop pressure if it isn't in use?
Then it's a matter of looking under floorboards, and isolating sections of pipework to tell what you can.
If the pressure vessel is low on precharge air pressure, it seems worse because a small loss of water means a large drop in pressure, so you could check that. See Faq Section - Boiler Pressure Problems
