- Joined
- 29 Jul 2006
- Messages
- 9
- Reaction score
- 0
- Country
Hi all,
First things first, what I know about boilers could fit on a very small postage stamp, so please keep that in mind if/when replying!
I noticed earlier today that there was no hot water, and when I checked the boiler (see subject) I could see there was a fault (see subject). So, I dug the service manual out, brushed off the dust, and looked up the code. Apparently, code 1 is an ignition failure. I guess the clue was in the lack of burning gas!
There is some fault finding flow charts in the service manual, so I followed those, and it suggested replacing the ignition control, or if that's okay, the PCB. (clearly I have no idea whether the ignition control is okay - how to test ignition controls is not on my very small postage stamp)
There was also some other info about common causes of code 1, where it suggested that you check the gas supply (who would have guessed that air doesn't ignite as well), and that the polarity of the electrics is right (I get the feeling that the author of the service manual has watched far too many star trek episodes - reverse the polarity captain!).
Anyway, to cut a long story short, after following the flow charts etc, I did what any self-respecting software engineer would do, and google'd it. That's how I found myself here. So, after reading a few messages, I decided to restart the boiler a few times (using MS Windows does teach you something!), and to my amazement, it actually fired-up!
So, in case you're wondering why I'm boring you with my ramblings, the reason is that I'm wondering whether it is currently working more by luck than design, and hence whether it is worth getting someone to look at it. (we pay someone an annual fee for a service and breakdown scheme, which covers parts and labour, in case that effects your answer)
Oh, in case it is relevant, it has been unusually hot here recently. (a comment in one of the earlier messages mentioned that hot weather can cause this problem to occur - I think it said about sticky gas valves?)
James
James
