Vokera Linea 28 Comb. Boiler
Over last few months DHW supply has become unreliable; it gets to 52 oC and then switches off until temp drops to 28 oC, then it reheats. Each cycle is 3 to 5 min. CH seems okay. I suspect that the heat exchanger for the DHW is clogged with limescale, even though the water here in Leeds is not hard. Am I probably correct?
I have just signed up for BG HomeCare 100. The first service is next week. I am expecting that the engineer will spot the problem with the DHW supply. I am just hoping for a reliable diagnosis and reasonable quote to fix the problem. If I don’t like either I have the option of declining and walking away from the contract at no cost.
My questions are: What should the engineer recommend? Removal/ replacement of the heat exchanger, pressure cleaning of the DHW side of the boiler, descaling as well as pressure cleaning, something else? How long should it take and how much should I be charged? Forewarned is forearmed, in my book.
Thanks in advance for any help!
