Hello, looking for a little advice for anyone who can help point me in the right direction.
My central heating runs from the Vokera. It has 2 electric feeds out. one to a Honeywell froststat, and one to a 3a fusebox, which then feeds to a main wall control in another room.
The wall control panel and 3a fuse has blown, so I will need new ones. i put a new fuse in at first but that blew straight away along with a bang at the wall control panel.
I dont need anything sophisticated, just turn on and off frankly with a time setting.
Firstly , are all control panels compatible with the Vokera ? i was looking at this cheap one maybe: http://www.screwfix.com/p/flomasta-25901sx-single-channel-timeswitch/7635g
And second, before i spend £ on the panel, if i disconnect the current panel, will the boiler work from its own on/off knobs alone so i can test it is still ok first ? Previously , i could start the boiler from its knobs providing the control panel was set to on.
I'm assuming the controls are overidden by "inserting a link wire between terminals 1 & 2" as per the manual.
Thanks for any help, in advance.
