Vokera Vision 20S
15 May 2022
Cork
Ireland
Daughter's 10 year old 20S has begun to act up lately. Sometimes it takes 6 to 8 minutes to start up even after resetting it or turning it Off/On a few times.
The only alarm she sees displayed is 3 circles with sometimes 12345 and Alarm in text.
I had a look at it this morning, the boiler pressure was 1.6bar cold. I called it to start by putting one the zones to boost but it just sat there for over a minute doing nothing so I gave the casing a engineers judicious belt of my fist and off it went, I made it cycle several times and switched all 3 zones off and on but it worked perfectly well since. Presume this problem is a harbinger of trouble ahead, maybe PCB failing??.
If Vokera do a fixed charge repair, is it worth it? @vulcancontinental and others might care to comment.
Not sure of the alarm codes, but being a system boiler and lengthy start time, could that be indicative of motorised valve failure(s)?
if giving the boiler casing a whack gets it going it's almost always a sticky relay on the pcb or the fan sticking on initial startup mate. the vibration just frees the contacts or gets the fan spinning enough to make the air pressure switch. fine as a temporary bodge to get heat into the house but you'll definitely want a gas safe bloke in to check the pcb and fan before it dies completely in freezing weather.
It'll be the accessory PCB relay used to allow the boiler to be switched by 230v. I don't have the part number here but will get it for you tomorrow. You'll not need a gas installer as there is no seals or gas connection to break and then check. The other issue of the three circles does seem to indicate the boiler being isolated electrically and rebooting, something not connected to the relay possibly but too coincidental for my liking. I'd do the relay first, but it you wanted to cover both the fixed price repair would do that and is around £300 incl VAT.
Thanks for that. My daughter did say that the 3 circles etc appeared after she switched off and on the power, I didn't switch off the power when I tried it.
That's ok then, that's what should have happened. Switching off then on does not reset the boiler, it just goes through an air purge cycle. Get the relay, 15 minutes easy job.
Many thanks again.
I don't want to break any gas seal so do I just remove the "outer" casing to access this relay.
Technically, any work on the boiler is covered by the gas regs, but, as mentioned, this is a straightforward one.
