Hi there,
Iput a message on early bvut no one replied,
Can any of u sparkys explain to me what this voltage grop thing means as i am just doing about it on my sparkys course, its beeen mentioned as im doing series circuits.
Does it mean say if u have 3 resistors one say as a volt drop of 1oov the other 2 say they are the same resistance of 65volt drop, and its a 230v supply . At the 100v resistor does it mean it has lost 130volts worth of pressure at that resistor and the other 2 resistors have lost 165v each at their resistors.
So if the above is right does it also mean that the higher the resistor (ohms) the more voltage that resistor would get around it due to a build up of pressure like sqizzing an hse pipe say the water pressure builds up
behind it.
Many thanks
behind it.
Many thanks
