ECO -Max RMH63 or EMH100 does any one know if or how you can adjust the out put Voltage on one of these......er bits of equipment. (Being diplomatic) .
And in any case these devices will make no difference at all to the power consumption of anything containing an SMPS.
Nor anything with a thermostat, e.g. electric ovens, which will simply be on for longer, nor things like kettles which will take longer to boil.
Other countries supply electricity at 220v or lower. So your equipment is consuming more power than necessary. The Eco-Max Voltage Optimiser ensures electricity supplied to your equipment is exactly what it needs with no loss of efficiency.
The Voltage Optimiser is manufactured to highest standards in the UK and is easily installed by a qualified electrician.
It is a “fit and forget” solution, maintenance-free and with a no-quibble 5-year warranty.
With pre-HF fluorescent lights they could save a lot of power holding the voltage down but since the electronic ballast, they are pointless.
