Volvo V70 2004 60,000 miles power steering wining
14 Mar 2009
Manchester
When i first drive of in my Volvo it is fine then after about 6 miles when i turn corners there is a horrible wining noise coming from the engine or power steering it is worse when the car is turning corners slowly i have changed the belt but no better the fluid level is fine but i have noticed it is weeping out of the filler cap onto the top of the reservoir and i have to wipe it clean after every journey any help would be much appreciated i can do most work myself.
If its a whine sound and you are sure its related to the steering then it must be the pump.
Thanks KingboyD i think you are right i will change the pump, when you drive in a straight line ie on motor ways it is fine, the noise only happens when you turn the steering wheel. i am going to change it at the weekend and will let you know how i get on thanks again.
