VW caddy 2007 vintage
  • Thread starter Thread starter DP
  • Start date Start date
DP
10 Dec 2003
Glasgow
Need to replace dipped beam bulb
Any recommendations that will give better light
Also need to replace the wipers as on that are on are noisy.
Again what do you guys recommend
TIA
DP
Bosch wiper blades, should be the flat aero type on that.
Bulbs tbh I've got some real cheapo Lucas ones in my car and they are fine.
I tried the osram 70% brighter ones they were good, but they only lasted around a year, and tbh when I put the cheap bulbs in I didn't notice the difference enough to warrant the increased expenditure.
On the caddy I think the lenses went yellow, try giving them a polish up with the headlight repair kits you can get these days
  • Thanks
Reactions: DP
Brighter bulbs don't last so long so I don't go for the brightest available. Went for silver osram as good enough. Been in 3 years so far.
Wipers splash out on silicone ones
  • Thanks
Reactions: DP
Put some Osram Nightbreakers in the Freelander just over a year ago and they were noticeably brighter. They have a reputation for not lasting long, but they're OK after a year (albeit only about 5000 miles due to Covid).
Never had much luck with wiper blades. Expensive Bosh ones are no better than Halfords' own. The cheapest from a motor factor last less well though.
  • Thanks
Reactions: DP
