- Joined
- 24 May 2016
- Messages
- 3,817
- Reaction score
- 730
- Country
Just started and only on first selecting a gear in the morning. Happens selecting first or reverse. Any ideas lads.
Hi John, thanks for the quick reply. clutch pedal feels normal and goes to the floor (One of these clutch pedal down to start engine types). It is due an engine service. Are engine and gearbox sharing the same oil?How does the clutch pedal feel......are you able to press it right down?
Cold weather does accentuate gear selection issues, due to the oil being very thick.
John
Clutch.What does a heavy pedal indicate?
The clutch on our old diesel Golf started slipping a few years ago. I bought a new Sachs clutch and DMF kit - trade, it cost me £250.02. The clutch got better before I got round to fitting it. I’ve done at least 15,000 more miles in the car since then and it’s still going strong. Too late to return the kit now for a refund. Unless it goes on me, I can see me giving that kit away with the car when we eventually get round to selling it! I haven’t fitted a clutch to a car for at least 5 years now - not looking forward to doing this one either - a bit of a bugger to do on the floor.So long as the van doesn’t jump when you put it into gear, I wouldn’t worry about it for now, as any investigation would probably mean a new clutch and of course the dreaded dual mass flywheel.
The van doesnt jump just makes the horrible head turning crunching noise first thing and only the first gear selection of the day which I dont understand as to my mind shouldnt it happen every time I go from from neutral to a gear?So long as the van doesn’t jump when you put it into gear, I wouldn’t worry about it for now, as any investigation would probably mean a new clutch and of course the dreaded dual mass flywheel.
John
"The clutch got better"The clutch on our old diesel Golf started slipping a few years ago. I bought a new Sachs clutch and DMF kit - trade, it cost me £250.02. The clutch got better before I got round to fitting it. I’ve done at least 15,000 more miles in the car since then and it’s still going strong. Too late to return the kit now for a refund. Unless it goes on me, I can see me giving that kit away with the car when we eventually get round to selling it! I haven’t fitted a clutch to a car for at least 5 years now - not looking forward to doing this one either - a bit of a bugger to do on the floor.
Yep, I can’t understand it either. I don’t generally go around laying out two hundred and fitted quids here there and everywhere that doesn’t need spending."The clutch got better"
Something else I struggle with as most thing get worse with wear.
