Hi everyone,
I have recently stripped down a whole bathroom to redo. I've installed Aquapanel 120x90cm on all of the walls, and put down 18mm ply wood on the floor, as well as a shower tray. The wall tiles are 33x25cm, and the floor ones are 40x40cm, and I've got water Resistant powder Bal Rapidset Flexible Grey 20KG adhesive.
I had a few questions which I would appreciate if anybody could answer;
-Firstly, would you recommend that I start on the walls or the floor for tiling?
-Secondly, what size Trowel would be the best to use for spreading the adhesive on the walls and floor?
-Thirdly, what size of spacer would you recommend for the walls and floor?
-Finally, on the Aquapanels, is it necessary to use a PVA coat first, or can I go in straight with the tiling adhesive?
Thank you in advance guys.
