Hi
Getting an extension planned out and need some advice on how to get the most of the available space. I live in a terraced townhouse which 4200mm across (narrow innit) and want to put a 4m oak framed garden room on the back with a pitched roof.
Story time... We're hemmed in by neighbours extensions on either side which are mono-pitched but only about 3m long so can't follow their roof line, besides we want the higher ceiling space. Usually with a garden room the whole thing is built of oak pillars and the sides are fully glazed but there wouldn't be much point so the far end will be fully glazed with french doors and the side walls will just be solid masonry. There should still be plenty of light once we've got a couple of Veluxes in the roof, plus the garden is south-facing.
So assuming you're still awake after that, here's the problem. The architect (works for the oak company) is saying we need 300mm walls at the side (pretty standard) and this is in addition to a 175mm gap for guttering at either side (due to pitched roof design). So 4200 - 350 - 600 = 3250mm which leaves the extension significantly narrower than the kitchen it will join on to.
I've asked building control and they said we might be able to go to 250mm with a masonry cavity wall but that only saves 100mm.
I was wondering about insulated panels/ SIPs but the designers says (someone else told me the same) you can't install panels without access to both sides of the wall... anyone know if that's true?
Any other ideas?
Any other ideas?
