Hello,
I would like to use kingspan roof tile panels (100mm) - which look like a tiled roof for a side extension to my house comprising a garage and utility room.
The plan size of the extension is 8.4M x 3.07m. I would seek to
minimise the roof pitch (12 degree, 15 degree?), which would be
mono-pitch away from the house wall. The roof would be supported by
215mm block at each side.
What support would I need to provide to the roof tile panel, with the aim
of MINIMISING any rise in roof height or intrusion of the supports into
the room?
This structure would have to comply with building regulations.
I also to intend to use the same panel to re-roof an outbuilding 3M x4M -
building regulations compliance is not required.
The xlforte type of panel would be used - lighter?
regards
Graham
the room?
regards
Graham
