Wall hung basin on steel studs + waste in wall
15 Dec 2008
London
Hi
I've started renovating my bathroom. My girlfriend would like to replace our pedestal wash basin with a wall hang one as she thinks it will look cleaner.
The wall is a metal stud wall with plasterboard covering. If it was wooden i would of had a go at nailing in some boards between the verticals to hang the sink on. I'm a bit stumped with what to do with a metal stud wall.
Additionally I would need to run the pipes horizontal within the stud wall to achieve the desired effect. I believe there are holes in the uprights that should accommodate 15mm copper pipes but am unsure about the 32mm basin waste. Could i drill the uprights to take the basin waste?
Here is a picture of another part of the bathroom wall to illustrate what the stud wall looks like.
Here is our current sink which shows the boxing she wants rid of. The pipes originate from the left of the picture and turn 90 degrees to supply the sink. I was planning to extend them into the wall before turning 90 degrees to approach the sink within the stud wall.
Cheers
EDIT
OK I've looked into this some more and taken some measurements.
The tracks are 45mm in width and the studs sitting within them are 41mm. I'm assuming the studs are nailed to the tracks where they meet.
So to strengthen the wall I could install an additional stud, either wood or metal within the tracks and then hang some plywood on it within the studwall and then plasterboard on top.
Anyone got any experience with this scenario?
This would still leave the problem of running the basin waste within the wall. I would likely need to drill holes in the studs to accommodate the passage of the pipes. How safe is this? I don't believe it to be a load-bearing wall - just an internal partition wall to the best of my, admittedly, limited knowledge.
I would appreciate the benefit of your combined experiences.
Cheers
as an alternative how about continuing the boxing around to encompass what looks like the rad pipes to the right of your existing sink? I did this in my bathroom and tiled the lot - the 'shelf' this made has proved well handy for cleaning products and the like . . . . perhaps this wouldn't work in your bathroom though . . . .
Huey
