As i am in the process on insulating the garage i have got lots of good advice on here which has helped me. Now i have come to insulate the house side of the garage which also has the existing lights switches and socket on it.
This is where i have run into a problem, my plans and materials are to place 50mm of xtratherm\celotex\kingspan insulation against the wall, cover this with with 25mmx50mm battens and then plasterboard on top.
The problem is the existing switches and sockets on the wall have the cables coming from directly behind them. So these will need to be pulled forward to sit infront of the insulation\batten\plasterboard. In turn this means the exisitng ring main and lighing cables will need to pass through the insulation board. What would be the best way of doing this, either make a small hole for literally the cable of make a bigger hole say the size of the switch\socket to allow the cable to be clear of insulation and have a decent air gap around it ?
thanks
dave
thanks
dave
