Hello
I am due a rewire and need to chase out the walls for wall lights.
I am hoping they will be controlled from the main switch by the door.
I don't want to dig to deep in a long line as the walls are bad and the cavity is exsposed when i put a back box in ( so needing to rebuild it back with concrete)
So If only one run of wire is going down what is the minimum depth I can chisel out Unless it would be 2 runs and so on.
thank for any advice
OJ
OJ
