wall mounted switch for water pump... is this normal?
24 Jan 2005
There is a switch on the wall in my hallway which supplies electrical power to my water pump.
Before I bought the flat, I rented it and the land lady told me to never leave the switch on unless I needed the pump.
I'm about to replace this pump and was wondering, do I really need this switch or should I simply supply power to the pump directly and let it do it's thing whenever?
What have you all seen out there?
That rather depends what water the pump pumps where!
I think the landlady was right. Never, ever turn the pump on unless you actually need the pump. Sound advice.[/b]
If the property starts sinking, turn the pump on fast :LOL:
kevplumb said:
this thread wouldnt have anything to do with this one woild it
Yes, this is the same pump. To install the new one, I'm wondering if I should keep this switch or just wire it directly. Sounds like it's up to preference, though I haven't ever seen a switch in any of my friends' houses which use pumps.
Sounds like u got a boiler which runs ur hot water off gravity.When u want heating u switch the pump on.Was there once a solid fuel boiler in the property?
There's a boiler for the central heating for the block of flats I'm in. However, the pump I have pumps from my hot water cylinder (heated by an indirect coil flowing with central-heating hot water) and my cold water storage. Because it's one level flat, and all water pressure comes from the cold water storage tank, I need a pump in my flat to get adequate pressure.
Because my fancy new shower is a fixed head located higher than the CWS, I have a negative head situation... hense the new pump which operates in negative head settings.
