The network cables are 30mm from the power lead, the rest are in between.
You may not have network, signal etc cables in the same containment as power ones.
Your point is?How many people bind all the cables in those twisty cable tidies which presents the same effect,
Did you look for information on mixing Band I and Band II cables, or was that something you didn't look for because you had no idea it even existed?I did look for information before doing the job and the main bit I found was if burying the live it needed to be on an RCD protected circuit which it is.
