- Joined
- 12 Oct 2024
- Messages
- 277
- Reaction score
- 61
- Country
Hello,
We are having a house extension built, single storey with a hipped roof. The builder has built the inner skin block work up (fibolites I think) but found that there is an awkward height difference from the current top of the block work and the wall plate of the existing bungalow, which the roof must tie in to.
In order to make up the difference, he could cut 20 fibolite blocks in half and then use the 4x2 wall plate called for in the roof instructions. This would be a crap dusty job for him though. So he has suggested making up the difference by instead adding a course of concrete commons to the top of the blockwork and using 4x3 as the wall plate.
Does this seem reasonable? He says it will be stronger and better if anything. The only issue I can think of is extra weight. He says the building inspectors usually prefer the same material for the inner skin, mentioning a time when he used to do the corners of blockwork in brick. I assume that was to do with thermal values though (?) and this proposed top course is above the insulation anyway (above the outer skin).
I would be most grateful for any views on this.
Thank you
John
Thank you
John
