wall prep for rendering a few pointers please.
17 Jun 2008
Warwickshire
hi all.
i have a a section of house wall that needs rendering. roughly 2M X 8M
the house is fully render except for the gable side where it is only rendered on the ground floor.
the render was in a real state so it was removed.
the render came off well but revealed the brickwork beneath to be 90% blown bricks. some upto 40mm back from the face.
do i go round filling all the holes/blown brick in first. in stages, slowley getting it back to level? what the maximum depth i can have of render? i think its going to need 4 coats of so to get nice and flat.
also what sort of time should be left in between coats?
thanks for all your help
ian
5 Aug 2007
Hose the wall down, just go along and fill the holes first just before you scratch coat, with the same mix,
some like to top coat the next day, some the same day, some a week later.
17 Jun 2008
Warwickshire
thanks.
is soaking the waa down with water good enough, no need for pva or sbr?
is it ok the fuly fill the holes in one hit as some are really deep or should i build them up slowly
tahnks
ian
21 Nov 2008
uk
a coat of sbr will do no harm! block the deeper cavities out in a couple of coats, if you go too heavy the mortar will slump.
