I have knocked my kitchen and dining room into one and in process have completely removed one wall which had a single socket as part of the main ring circuit (And a dodgy spur wired into this by previous owner completely hidden inside a cavity wall!).
1. I want to relocate this outlet to another wall in the dining room, is it OK to do this with 2 junction boxes and then run cable to the new sockets and back to same location to re-connect the ring? JB's will be under the floor, (I know I should really locate the 2 sockets either side and join new sockets into these but don't really want to have to damage plaster etc around the 2 sockets to replace the cabling.)
2. I now have a kitchen light and dining room light in essentially the same room and the kitchen light switch is now in a place which would be awkward to access when new kitchen layout fitted so i have two options - Remove this switch and run drop cable to dining room switch and replace with 2 gang switch which will involve chasing a solid wall to fit cable or run both light fittings from the existing dining room switch - how do I wire this in? Is it just a case of running a cable from dining room light fitting to kitchen fitting and wiring in place of the existing switch cable?
3. I want to connect a socket outside for power and to run some lighting, is a spur from existing socket (On a ring) into an RCD FCU such as http://www.screwfix.com/prods/14770/Electrical-Supplies/RCDs/Powerbreaker-13A-RCD-FCU one of these and then to the outside the best way to do this?
Cheers
Cheers
