Wall Starters or debonded wall ties
12 Dec 2020
I'm building a double storey side extension, the plans specify movement joints where the extension meets the house. Is this required or can I just use standard wall starter kits?
Do you think the movement joint on the plans is for some sort of vertical movement tie rather than horizontal movement joint. Is there any problems with cracking using wall starters?
I'm not sure if they are needed though. Is it common place to just use standard wall starter kits?
Normally standard kits, but you need to check with the designer whether slips are required.
Thanks, it's quite difficult getting a response from him now. I can't see why slip ties would be needed, cavity wall construction brick and block on to 1930s brick and block house.
Can be if a raft foundation is used next to a strip foundation and some movement is allowed for.
It would be a crap designer that specifies a movement joint instead of a tied connection. Perhaps he just doesn't know the difference but actually meant to specify a flexible tied joint to allow for movement?
