    Dismiss Notice
Wall Starter kit
Discussion in 'Building' started by Sam8_8, 7 Jun 2021.
  1. Sam8_8
    Sam8_8
    7 Jun 2021
    4
    Thanks Received:
    Country:
    I am having a rear extension done and being a bit of novice, don't know much about building works. The walls are starting to go up and I noticed the brick guys used wall starter kit only on the outer leaf and didn't use it on the inner leaf (blocks) . Is this acceptable? or should I ask them to remove a few blocks where the wall joins and use starter kit?
  2. Sponsored Links
  3. stuart45
    stuart45
    13 Sep 2008
    3,090
    Thanks Received:
    472
    Somerset
    Country:
    Wall starters should be used for blockwork as well.
  4. noseall
    noseall
    2 Feb 2006
    41,836
    Thanks Received:
    2,611
    Staffordshire
    Country:
    Not really unless they are using another method to tie in...?
  5. ^woody^
    ^woody^
    3 Sep 2006
    32,743
    Thanks Received:
    4,426
    West Mids
    Country:
    Oh dear. That's £20 and 10 minutes they've saved. Watch out for any other efficiencies. :cautious:
    • Like Like x 2
  6. noseall
    noseall
    2 Feb 2006
    41,836
    Thanks Received:
    2,611
    Staffordshire
    Country:
    I agree. It costs very little to do both leaves once the drill and impact driver are set up. My oppo loves fitting them.
    Doesn't bode well.
  7. Sam8_8
    Sam8_8
    7 Jun 2021
    4
    Thanks Received:
    Country:
    Don't know why they do silly things like this if its only 10 mins to do it properly..is this work i.e. tying new walls to existing checked by BCO? Should i raise it to him if they give me excuses?
  8. stuart45
    stuart45
    13 Sep 2008
    3,090
    Thanks Received:
    472
    Somerset
    Country:
    Just insist on the job being done properly.
  9. ^woody^
    ^woody^
    3 Sep 2006
    32,743
    Thanks Received:
    4,426
    West Mids
    Country:
    Do you have any plans? What do the plans specify? If the builder has quoted based on the plans, then at the minimum you can expect work must be as specified. Any deviation from the quoted work (ie the specification) should be only with your prior notice and agreement.
    The inspector wont inspect for these ties
  10. Sponsored Links
  11. Sam8_8
    Sam8_8
    7 Jun 2021
    4
    Thanks Received:
    Country:
    Yes i do have plans and this is what they say about walls "WALL CONNECTOR-NEW WALL CONNECTED TO EXISTING WALL WITH 'FURFIX' STEEL CONNECTOR OR SIMILAR. POLYSULPHIDE SEALANT POINTING TO EXTERNAL JOINTS. - INTERNAL LIGHT WIEGHT BLOCKWORK PARTITIONS TO BE PLASTERED."
    I will ask him to take out a couple of blocks from the wall and insert the starter kit. For my information, what are the implications of this not been done on inner leaf? Will inner wall have cracks?
  12. cdbe
    cdbe
    22 Nov 2009
    1,154
    Thanks Received:
    202
    Oldham
    Country:
    Pull wall over when builders leave. Plead ignorance and wonder if it was tied in properly as you all look at pile of blocks in the morning.
    • Like Like x 1
  13. Sam8_8
    Sam8_8
    7 Jun 2021
    4
    Thanks Received:
    Country:
    Haha sounds like a plan
  14. Laggy
    Laggy
    27 Nov 2020
    22
    Thanks Received:
    Country:
    Why £20, I’ve been paying £10 from screwfix and now I’m about nine sets deep I’m furious I’ve just seen the same ones go for £50 for ten, brand new on ebay
  15. catlad
    catlad
    29 Jul 2011
    4,655
    Thanks Received:
    699
    Lancashire
    Country:
    Tell them next doors cat jumped on the wall.
  16. ^woody^
    ^woody^
    3 Sep 2006
    32,743
    Thanks Received:
    4,426
    West Mids
    Country:
    Two packs :rolleyes:
  17. Laggy
    Laggy
    27 Nov 2020
    22
    Thanks Received:
    Country:
    One skin
Loading...
Share This Page
