Hi.
A friend has asked me to lay some blocks for a small barn on his farm. The building uses vertical steels (rsj's) to support the roof. The blocks in theory aren't structually relevant to the building, more to enclose the sides and keep the elements of the cows!!
The back and front walls are easy as the blocks can be slotted into the recess in the rsj's. On the sides its a bit more tricky. I really don't want to drill the rsj's to fit a conventional wall starter kit, i've tried welding but the steels require so much heat to get penetration that it just burns straight through the tie.
So any ideas? any super thick wall starter kits that will take welding?not bother with them?
Cheers zeb.
Cheers zeb.
