Wallpapering over unusually shaped external corner
12 Oct 2018
Does anyone know the best way to wallpaper over the external corner which has an unusual shape as per attached pics? The external corner is rounded which is no problem but at the top and bottom it peaks or slopes into a right angle. I just want to avoid making several awkward cuts that would show
I am using ordinary medium weight paper. Thanks in advance.
I love those old corners.
Hard to describe, but yes, there will be some awkward cuts.
The trick is to make sure the edge of each seem is not facing where you would generally see it, if you see what I mean.
