    Dismiss Notice
WalWiz
Discussion in 'Decorating and Painting' started by Growler, 20 Jul 2008.
  1. Growler
    Growler
    11 Mar 2006
    793
    Thanks Received:
    50
    Country:
    Any of you guys use one of these instead of a papering brush.
    There's probably an old duffer that's set in his ways around here, thats never even heard of one. :LOL:
    Brilliant little things for getting paper into corners and holding and cutting.
    http://www.usawallpaper.com/wa3in1wato.html
    Now.... where is that "old duffer".
  2. Zampa
    Zampa
    14 Mar 2005
    5,779
    Thanks Received:
    30
    Country:
    You called???? :LOL:
    Been using one since about 1978..are they new 'op noooorth' then? :evil:
    These factory made ones are a bit on the small side IMO...handy tools..but you have to be careful when your..
    Using on a non vinyl...
    Using on uneven walls..
    Using on walls where they might be a risk of the odd nib..they could rip the paper.
    You also have to be careful that you dont push/pull too hard and cause the paste to squidge out from the seams..and as they are fairly thick you dont always get a tight cut along skirts and the ceiling line..
    3 quid for 30p worth of plastic though....bit steep...far easier to keep you eye out for a discarded bit of shop sign and make your own
    Tell what is good though....a longish pile roller sleeve for smoothing the paper out with...compared to a 35 quid hamiltion paper hanging brush.
    Not much good as a straight edge when cutting though :rolleyes:
  3. Sponsored Links
  4. Zampa
    Zampa
    14 Mar 2005
    5,779
    Thanks Received:
    30
    Country:
    Growler..are you coming out to play??? :evil:
  5. JohnD
    JohnD
    15 Nov 2005
    65,261
    Thanks Received:
    3,498
    Morecambe
    Country:
    Cook Islands
    Ultimate South.
  6. Sponsored Links
  7. Zampa
    Zampa
    14 Mar 2005
    5,779
    Thanks Received:
    30
    Country:
  8. DIYnot Local
    3 Sep 2019
    Country:
Share This Page
