Want to install PIR in downstairs toilet
7 Dec 2003
Hi
In my downstairs toilet I have one low voltage spotlight with is switched on by a standard pull cord. There's no other source of light so I was thinking of installing a PIR so the light automatically comes on.
Can I install a ceiling PIR between the switch and light?
Cheers
I'm not sure about the neutral, how can i check and what difference does that make?
some PIR switches require a neutral to work. you need to have a meter to find out for sure
Make sure that you set the time for long enough, otherwise you'll be sitting there, contemplating your navel, and you'll be plunged into darkness :lol:
