hoping theres an easy solution - just put up a 8ft wardrobe and due to sloping floor i connected it to the wall in case it woudl tip over once i filled with stuff. only problem is - now the wardrobe is level the front part sits about 1.5 ins of the floor - and the adjustable legs arent touching the floor so it has an appearance of floating above the floor. if i put a wedge or enough wood underneath where the feet are woudl this support the weight that will go into the wardrobe as my concern is that the weight might pull the wardrobe from the wall in time.
or is there some other solution that can be use.
thanks in advance
thanks in advance
