- Joined
- 1 Mar 2005
- Messages
- 31
- Reaction score
- 0
- Country
I'm looking at installing some lighting inside a wardrobe. The plan is to use a flourescent tube less than 20W. I found this switch which might be OK for turning the light on when the door opens: http://www.tlc-direct.co.uk/Products/FM143.html, but it says it's rated at 2 amps.
I'm sure a 20W light would be less current, but would I need to put in a fuse of less than 2 amp to protect it? Can you get 1 amp fuses, the smallest I've seen is 3.
Any advise would be great, I'm still just planning so I'm open to alternatives.
Cheers.
Cheers.
