Hi all, I have fitted british general "BG" Nexus accessories around my kitchen as the old ones where all scratched, the accessories are the low profile type with the screws filed flat with a finishing metal plate to hide the screws. My only concern is the cooker 45 amp isolator switch is warm to the touch even when the cooker is not in use, All the connections are tight and it is wired up correctly, I can't hear any arcing from the switch when the cooker is running nor smell any burning, I would imagine if it was arcing it the switch would be getting hot straight away and too hot to touch The isolator has a red neon could it be the resistor for this neon making the unit slightly warm? The switch has been installed for 3 days now, , Is it just the heat from the resistor I am feeling? or could the switch be faulty?, Like I say I cannot hear any arcing internally from the switch even with the cooker running, its a fan assisted oven which draws around 12 amps, I am sure if 12 amps was arcing you would certainly hear it crackling and maybe smell burning?, Am I just worrying over nothing? Is it just the resistor or something similar for the neon? The switch does not get any warmer when cooker is running, it stays at the same temperature which is just slightly warm. Also what are your experience and opinions with the BG nexus products?
thanks
thanks
