Washing Machine cold water feed
23 Sep 2006
I need to shorten my cold water feed it is on a plastic 15mm pipe what do I need to shorten it. Cheers.
You will need to cut it with a plastic pipe cutter., make sure you use an insert again when redoing the fitting.
Can I not just cut the pipe with a hacksaw, is it possible to buy the inserts singly.
