washing machine door switch ariston automatic washer
20 Jul 2009
:( I am going crazy.i live in china and a guy came to put a new lock on my machine,took the old one off and it took me a month to get a new one.i cant get hold of him to come back.there are 3 wires 2 red joined together,and 2 brow separate.How do i find out which is live,neutral and common.i know what the components are in the machine so if you can help me to put them back i would be most grateful.its an 11 year old machine mechanical not electronic.many thanks for your help.
I am not 100% sure but my guess would be that the 2 reds are the live & should go to the switch common terminal & the 2 browns should go to normally open & normally closed contact terminals although which one to each I do not know, it may be worth trying them each way & see what happens,but it is up to you. You may get someone else giving the precise answer you need so do not rush into anything, I am just trying to help & this may not be the correct solution.
