Washing machine trips rcd
18 Feb 2013
Birmingham
Hi, my new tennent called me to say when they plugged the washing machine into the WM plug socket it trips the rcd.
I went to investigate and the tennent informed me that they had used the washine machine at there old house for 18/24 months and it worked fine. They did say they had an old fuse board.
Everything else in the kitchen worked fine, with washing machine unplugged, and when I tried WM in a different socket it tripped Rcd again.
I then switched everything off in the whole house, re set rcd and plugged WM into a socket above work top, as soon as I turned dial to switch WM on the rcd went again.
The 2 previous tenents had no problem with there washing machines. Is it fair to say the machine has a fault not there is a problem witn the property electrics?
Thank you
Yes there's a fault with the mc. Could be heater motor etc
