Hi all, planning for a bathroom reno and have some concerns over the 'roman' bath - effectively a tiled shower with a tall hob and a waste outlet which can be plugged. Put the plug in and water fills up to create the bath.
I can't seem to find any waste outlets specifically designed for this. I'm worried that if I use a typical bath waste outlet then any water run-off that seeps through the tiles/grout underneath onto the membrane will not have the usual escape route down the waste outlet as you would on a normal tiled bathroom floor.
Does anyone have any experience with this? Any suggestions?
Cheers,
Bas
Cheers,
Bas
