    Dismiss Notice
Waste pipe to soil stack leak
Discussion in 'Plumbing and Central Heating' started by Jarmex, 13 Nov 2016.
  1. Jarmex
    Jarmex
    12 Nov 2016
    2
    Thanks Received:
    Country:
    Hi all,
    I have recently noticed a leak between the soil stack and a waste pipe coming from the bath drainage (see pics). Unfortunately the joint is both under the bath and next to the toilet, making access difficult. I think the connection is solvent welded, which is a pain, but I'm not 100% sure so I've attached pictures to help identification (note: it look like the pipe runs uphill, but that's just a bad camera angle!)
    [​IMG]
    [​IMG]
    Would anyone know the best way to attempt to fix this leak? I don't really want to have to pull the bath out unless absolutely necessary!
    Thank you very much,
    James
  2. gigz
    gigz
    7 Oct 2006
    8,427
    Thanks Received:
    2,282
    Country:
    If you can't get access i would thicken solvent cement around the joint and push it into the joint as much as you can. Denso also does. Personally i would cut the pipe at an accessable point, make leaking joint good then put a straight connector on.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. Nige F
    Nige F
    28 Jun 2005
    21,206
    Thanks Received:
    1,741
    Country:
    I might if I could see the pics.:unsure: But you can't go far wrong wrapping with denso, just wear rubber gloves
    • Thanks Thanks x 1
  5. picasso
    picasso
    8 Apr 2008
    10,631
    Thanks Received:
    2,667
    Essex
    Country:
    I would go with a couple of fernco couplings, cut the pipe and slip one over the leak and the other one to join the pipe you cut.
    • Like Like x 2
    • Thanks Thanks x 1
  6. Sponsored Links
  7. Jarmex
    Jarmex
    12 Nov 2016
    2
    Thanks Received:
    Country:
    Thanks all, is anyone able to identify it 100% as a welded connection rather than a push fit? I did try to remove the leaky pipe but couldn't seem to budge it. If it is, I'll probably try denso as suggested above, and failing that, use the fernco couplings as suggested by picasso. Thanks again!
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
