- Joined
- 6 Jun 2008
- Messages
- 18
- Reaction score
- 0
- Country
I have an oil fired aga which provides all the hot water in our house, we also have an old oil fired boiler which provides only the central heating via a large bore single pipe system.
All very old stuff and in need of replacement.
I want to start with the central heating so I'm intending to put UFH upstairs only.
Rather than feed the UFH directly from the boiler I want to feed it from a new hot water cylinder.
The idea being that the aga would be the primary heating coil in the cylinder with a secondary coil which would call the boiler under certain circumstances, as a third heat source there should be immersion heaters to increase water temperature overnight using economy 7.
Is this feasible from a hot water cylinder and if so does anyone know a manufacturer that can provide one?
Cheers
Andy
Cheers
Andy
