well thats true if you think that laterally, however what if the canal is only as long as the via duct Hmmmmmmmmm
the bouyancy and mass are different and irrelevant in this case.
the weight will tranfer to the viaduct.
wether the object floats or sinks.
its density dictates wether it floats or sinks.
if the mass of water displaced by the object is greater than the mass of the object then an upward thrust equilvalent to the mas of water displaced is exterted on the object so the level of bouyancy is equal to the mass of displaced water minus the mass of the object.
That's why there are never lock gates either side of an aquaductIf the barge weighs10,000lb, it will displace 10,000lb of water, which will then be evenly distributed through out the canal system.
as i said, an object displaces a volume of water equivelent to its physical size,
No, a barge will only displace, about a third of its physical size.
Doesn't matter, you are still wrong.naughty i didnt say barge i said object.
quote the statement not a selective part.
with respect if that were the case then the object would be neutrally bouyant.
ie if its 1 cubic meter and it is physically held under the water it will displace 1 cubic meter of water, if the object weighs less than the weight of a cubic meter of water then it will float, more and it will sink.
This thread is about an object floating in the water. a floating object displaces water equal to its own weight, not its own volume.
possibleyAh! but would it take off?
possibleyAh! but would it take off?![]()
