water in tv aerial cable
2 Oct 2004
:o
Hi
i have a bad tv picture happened in 4 hours *poor signal* and have found water :cry: in tv aerial cable(connector corroded ) !! What is the best fix for this ?
TIA
ps if this is wrong forum can a mod move it :!:
some new cable would be a good idea. and make sure water hasnt travelled along the cable and into TV/sat box/DVD player etc.
how did it get in to start with? if you can use water tight connectors, use selfamalgamating tape
Will try some new sat cable cat100 ? and renew aerial too.
Not sure how water got into cable but all happened in about 4hours :!:
Connector was corroded so its happened before/ongoing will replace everything upto tv or will i need a new tv soon too ? :cry:
TIA
TIA
it should have built up in the cable and not reached the TV, but depends on the cable run. very unlikely to get into TV.
