    Dismiss Notice
Water ingress around inside kitchen window
Discussion in 'Building' started by BathDIY, 3 Mar 2021.
  1. BathDIY
    BathDIY
    23 May 2017
    287
    Thanks Received:
    8
    Country:
    Have noticed some signs of what looks like water ingress inside my kitchen window. Have been outside, removed the strips around the window and siliconed back in (which hasn't helped).
    I now notice that there are no gaps in the brick joints above the window (which are present on other windows on this part of the property). I believe these allow the water from the cavity drip tray to safely exit the wall/cavity.
    Any thoughts? What can I do about this issue?
  2. Sponsored Links
  3. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,940
    Thanks Received:
    1,982
    Hertfordshire
    Country:
    What's the guttering like, is there a gutter joint above the corner of the window?
    Andy
    • Thanks Thanks x 1
  4. BathDIY
    BathDIY
    23 May 2017
    287
    Thanks Received:
    8
    Country:
    The guttering was poor but it's now (late last year) been redone and is fine.
  5. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,940
    Thanks Received:
    1,982
    Hertfordshire
    Country:
    Was it leaking onto the window?
    Andy
  6. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,940
    Thanks Received:
    1,982
    Hertfordshire
    Country:
    Draw around the damp mark with a pencil and write the date next to it, then check in 2 weeks to see if it has got bigger or smaller.
    Andy
    • Thanks Thanks x 1
  7. BathDIY
    BathDIY
    23 May 2017
    287
    Thanks Received:
    8
    Country:
    No not (noticed) it hitting the window itself although I would guess it may have come close-ish in very bad weather (it's a 2 story house kitchen on the ground floor).
    I would guess that the guttering was leaking (downpipe blocked) for some time.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
