Hi everyone. We have an ancient Potterton boiler, Flamingo 50s, which so far been regularly serviced and cleaned.
Twice now we have woken up to no hot water. The timer clock is set, the boiler casing feels warm but when we run the hot tap the water is tepid. The system is gravity feed for hot water. The motor valve and thermostat are not connected on the upstairs tank and we have a pump as usual for the heating. If we switch on the central heating everything fires up ok. The water-only bit is then fine until the next time. Any ideas? The heat exchanger has a small crack and "kettles". Could it be this?
