I live on a top (fourth floor) of a 16 meter high building in which the kitchen is connected to the water mains but the bathroom and the toilet are connected to the cold water tank.
The estate management company has just reinstalled a new cold water tank in the loft rather than connecting everyone's bathroom to the mains siting the following reason:
The water pressure we have is well above 2 bars, if I remember it correctly from when we had a combi bolier installed. And I did a quick water flow test myself and established that it is a healthy 35-38 litres per minute.
We have ten flats in our entrance (from ground to fourth floor).
Do you think that water mains with the pressure and water flow I have stated would be enough for actually connecting us all to the main without affecting, for example, the boiler operation. The top floor flats have very poor flow from the water tank at the moment anyway.
Any advice would be appreciated. Thanks
- Thames water can only guarantee a minimum of 1.0 bar from their water mains.
- 1.0 bar of pressure has the equivalent force needed to raise water to the height of 10 metres.
- You lose 0.2 bar of pressure every 2 metres as a rule of thumb.
- This means Thames water can only guarantee a maximum 0.2 bar to properties 16m high.
