Hi all, after some advice, ref a single rising water main in apartment block of five flats. It has a 25mm water main entering propery, whicy feeds two ground floor flats. the three further flats are fed off 15mm, that comes off the single 25mm riser. The incoming water pressure is 2.2 bar, and 2 bar by the time it reaches top flat, with 14lm flow rate. Just wondering if this sounds correct.
