water pressure gauge
17 Feb 2006
Blackpool
I have a broag remeha avante plus and I would like to fit a new gauge .......is it a fairly easy job .......the boiler is working perfectly except for the gauge
Many thanks
Rob
Its only easy if you know how. The fact you have asked, makes me doubt your abilities.
obviously you haven,t done a psi gauge on a broag remeha-----with the gas off , i reduced the water pressure to allow removal, first checked for blockages but line clear, removed the said gauge, fitted new one, and repressurised the system, gas on, 3 minute start phase on boiler, then adjusted new gauge to operational setting---------hope this helps
rob
