L
latz
Hi Everyone!
Newby here looking forward to becoming a full fledged member
Ok so here is my problem... Have bought a Triton Topaz T100Si (the chrome one) which is 9.5kw requiring a min of 1bar inlet pressure to operate. Have fitted it and have connected the inlet to a compression fit which then connects to plastic speed fit pipe to the mains.
The problem is that when i switch it on, it switches back off in 2 seconds saying LP for low water pressure. Water will come out of the shower head but very slowly and only for a couple of secs before it shuts off automatically. It will do this as many times as i try to switch it on.
I have checked the inlet filter to the shower to make sure no debris is trapped and i checked the water flow visually only i.e. to make sure water would flow through the pipe leading up to the shower. I must admit it didn't seem to be under any great pressure like the rest of the house but i thought that was because it was going through 15mm pipe and not being squeezed through a fawcet of any kind.
I wonder if i have done something to this plastic speedfit pipe that is reducing the water pressure to the shower? or have i fited it in the worng place? The mains water comes through in the basement on 15mm pipe. I tee'd into this (before any taps etc) and ran plastic speedfit under the living room floor, up through the wall where the downstairs chimney was under the bedroom floor and up in to the shower with a tap style isolator at the base of the shower.
Here are some things you should know:
The plastic speed fit pipe runs through where the downstairs chimney was.
The height from the basement to the shower is 5 meters.
The pipe run is about 10 meters.
the pipe diameter is 15mm from the mains to the shower.
No other part of the house suffers with water pressure problems.
Does anyone have any ideas why this could be?! I am more than happy to answer any questions if there is anything else you guys need to know.
