Water softener fitted cost?
11 Mar 2008
Wiltshire
Hi
Can anyone advise how much it might cost to buy a water softener, and how much to fit?
thanks
About £450 to buy.
Anywhere between £100-£1000 to install.
About £6/month to run.
If your outsied tap is near to where the water softener is sited then this will simplify installation costs quite considerably.
A typical cost for a supply and install Water softener would be in the region of £1k just to give you a figure.
It all depends on the layout of your property!
The softener should be in the supply to everything EXCEPT the kitchen tap!
Some combi boiler makers dont advise a softener in the supply to their boilers.
Tony
Tony
...and outside tap(s)
a lot of people have an additional hard water tap fitted to the worktop and the Kitchen tap soft
Franke Tri flow taps are very popular when a water softerner is added, Hot, hard cold and soft cold on a single tap
What kind of water softener are you getting fitted for that?
You cant even buy a water softener for £120.
