- Joined
- 20 Dec 2012
- Messages
- 127
- Reaction score
- 9
- Country
The Cold Water Bath Tap had been making a annoying popping noise when you run it and are in the Bath.
I thought it might be just needing a new Washer. When i took the Tap apart that was the case but there is also some water that does not seem to drain away from the Tap.
I have manged to fit a rubber Washer for now until i can get the right size.
Any ideas whats causing the small amount of water under the Tap not to drain?
