water underfloor heating in new kitchen extension
3 Aug 2005
Warwickshire
I am building an extension to my kitchen/diner and replacing the floor totally in the kitchen half. I currently have rads in the diner side - timber floor but I am interested in underfloor heating in the kitchen side and I am thinking of connecting into my existing hot water circuit. Where do you normally house the manifold for the underfloor system - would this normally go inside one of the kitchen cupboards? Do you think the syetm will work ok with rads in the diner side - will this affect the sensor - Does any one have any pictures of an installed system showing where the manifold is housed or any links to good sites?
The manifold can pretty much go where you want it locally to the extention, though you will need to route flow and return from your existing heating system.
Is that the best you can do ?.
Thanks for your comments so far
The randall-danfloss controller looks like it could be the answer
The kitchen part of the kitchen diner will be just under 20sq/m without any cupboards/appliance etc. With units appliances etc it would be around 12sq/m of floor that could be walked on - Why does the danfloss FHV-R say only upto 10sq/m?
I am also considering a plinth heater connected to the central heating - are these any good?
Not entirely sure.
Wirsbo use it with 14 sq/m.
Danfoss,s FHV-R installation rules state the following -
1- Solid floor with minimum 75mm screed
2- Pipe must be laid down in a snail pattern (though I would opt for double meander)
3- Maximum 15 sq/m floor area with 15mm pipe
4-Maximum 300mm centre distance between pipes.
5- Maximum flow temperature 90c.
Tukka, did you install the UFH in your kitchen?
Which method did you use please?
I'm in a similar situation having to replace a damp concrete floor and hoping to improve the heating in the kitchen area.
Can anyone let me know if the Myson valve system - that regulates return water temp - works for small areas.
Thanks in advance,
Graham
Which valve are you referring to ?.
Thanks for the reply Tukky
Baleza,
Sorry I gave confusing information. It is the Danfoss FHV-R valve that I am considering. Not Myson
My worry is that the incoming water may be relatively hot compared to a more expensive pumped system that regulates the flow temperature.
Thanks again for your assistance.
Graham
PS...
the kitchen part is only 3m x 2.25 m - and two sides will have units, so the floor area is quiet small.
Graham
The high flow temperature entering the loop is not an issue as the fhv-r will not allow this temperature to flow through the loop .
The high temperature soon becomes cooled due to the heat transfer between the pipe and the screed , down to the temp that the fhv-r is regulated at and causes no harm.
Considering the small floor area you have avalible I would opt for kickspace heaters or a radiator.
