Waterproof Wired Doorbell Push
12 Oct 2012
Bedfordshire
Are there any decent, neat, small waterproof (or at least splashproof/IP44) wired doorbell pushes? We used to have a great solid brass Friedland solid brass at our previous property, which never rusted inside so I assume it was waterproof, but it doesn't seem to exist now.
Our current west facing property has a crappy plastic Friedland/Bryon black+white type, which I've replaced twice in 5 years, it's now completely rusty again inside due to water ingress. All the ones online from the usual suppliers look the same, and none mention they are sealed or waterproof.
It's only a thin doorframe and needs to be surface mounted, so this rules out anything large and industrial looking like the fully weatherproof IP66 type grey switches you can get from tlc-direct (like MK and Timeguard), not that they would fit in with the decor anyway!
Any recommedations?
1 Mar 2008
Watching this thread with interest, as keen to fit something similar at my place - the bell push MIGHT last two weeks before it fills up with water, if I'm lucky(!)
16 Feb 2011
Sheffield
16 Feb 2011
Sheffield
The original technistore button came with a flat 20mm plate with the 20mm stainless steel button attached , you would have to drill a 25mm hole to recess the button and lock nut ...
30 Jun 2008
Suffolk
Yes, a liberal smearing over the contacts and also a bead around the edge of the back before mounting it.
I fitted one in a similar fashion to my first house on the second day of moving in, just a basic brass architrave style bell push, and did this to it. It was still working perfectly when I removed it 10 years later and fitted it to my next house. Re-did the vaseline and it was still working 6 years later when we left.
