- Joined
- 28 Nov 2016
- Messages
- 3
- Reaction score
- 0
- Country
We are having a small ensuite fitted in an attic room and as a result, the shower has a ceiling sloping from approx 2m to 1.5m, which means that the bottom of it is likely to get wet. It is tiled on 3 walls but the suggestion is to just paint the sloping ceiling with bathroom paint and blade it after use. My gut feeling is that this won't be enough as, as far as I know, bathroom paint isn't really designed to get wet, just damp. I have thought about the following options:
1) Tile the sloping ceiling. This seems the sensible option to me but there may be reasons it's not such a good idea?
2) Use an acrylic sheet as a splashback on the sloping ceiling
3) Use an epoxy paint or some other specialist paint which would be more waterproof. There are the damp seal paints which are supposed to keep damp out - would these work the other way if you like, i.e. keep water from the shower from soaking the underlying wall?
Any help much appreciated.
Robert
Robert
