Wax oils or linseed oil on Floor ?
9 Jun 2014
Yorkshire
Our downstairs area is a wood floor and i have used Osmo clear oil on it in the past. I have just done it again as it needed redoing. I will also have a whole new load of flooring to oil when my extension is finished.
Anyway i was talking to the oak framer about oiling the oak frame and floors and he said don't buy the expensive wax oils, just use a basic linseed oil from somewhere like tool station. He seemed to think the oak needed oiling every so often for the floor (say 2 yrs) and so it was more cost effective to use the linseed oil.
What do you reckon. Has anyone used a simple oil to see how long it lasts compared to the wax oils ?
I have just run out doing my floor today and i had the area under the sofa to do only. So i just bought a small bottle of linseed oil and have finished it off that way. It looks exactly the same as the Osmo oil. I will wait to see how it dries. It won't get any wear in this area as it will be covered over, but i may just go for the new area of flooring in this linseed oil later in the spring when the extension floor is down.
I am assuming the wax oil is a tougher oil than the linseed, but it would be good to see first hand the difference because longer term you could save a lot of money. We have mostly wood floors downstairs and the big bedroom is now wood floor. I am going to do my office in wood flooring as well. So oiling all this is going to be pricey at £75 a 2.5l tub of Osmo oil. Prob need 3 tubs every 2 years. 5l linseed oil at toolsation is £28. So £225 v £56 every 2 years.
what linseed oil have you used if it isn't boiled it will never really dry out, just soak in
I would never use it for a floor it will just pick up dust and dirt for ever and a day. It will also seriously discolour and yellow over time. It also has very poor waterproofing properties.
Boiled linseed oil is modified to speed up the drying process, but still dries slowly. I have a friend who makes guitars and he uses boiled linseed and leaves them to dry for about a week between coats.
Either should only really be used as a penetrating oil applied in very light coats it also affords virtually no physical protection.
I would stick with the clear osmo or use something like Bona
probably be OK I have never used it though. I pretty much use Bona exclusively now, goes on quick re coat in 4 hours, walkable next morning full traffic in 24 hours a gallon is around 70 quid but in the grand scheme of things its nothing really, a gallon goes a long way. Looked after it will last up to 10 years. I always clean mine with bona cleaner it provides a slight lacquer coating each time which provides protection to the varnish finish.
http://www.floorsalesonline.com/bon...ueFfmAGFZjmoJSCJRA9mqCQRFMSGyTdYaAtf5EALw_wcB
Is this the product you use Chappers ? Seems ok, certainly better on price.
The bit which i don't like is the need to use a primer before application. Would i need to prime a brand new wood floor then ?
What about using this product where i have used, say the Osmo oil. Can i just switch over to Bona on my next bi annual top up oil ?
Yep that's the stuff
I've never primed always just sanded to 150 grit, they say just two coats, but I'm sure I read somewhere on their own tech sheets that the alternative is to just use three coats I have found it OK to give three if the first coat really gets eaten up . I always denib with 400 grit (literally a wipe over)after the first coat even though they say you don't need to and wipe down with a spirit soaked cloth.
Not sure what the score is on going over the osmo oil, my instinct is you might have to strip it off, but I would check with Bona.
Edit; Have a look here re not priming and also what you can't go over without stripping back heres the official tech sheet.
